585,749 active members*
3,682 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Access data (common variables)
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jun 2015
    4154
    Re: Access data (common variables)
    hi
    I don't want to save all variables into pc. I just want to see them in the pc screen
    after you will finish the conection between machine and pc, you will run a program on the cnc, and that program will create a file on the pc
    if you wish to see the variables on the pc, then you need to create a program that will send the variables values to the pc ...
    the file needs to be opened on the pc screen?
    i don't know, because i don't use 232, but i don't believe that the file has to opened; it should only exist
    maybe 232 won't begin the transfer if the file is in use ... but, the conection, you will do it yourself ? or you will call someone? kindly
  2. #22
    Apr 2009
    1262
    Your vintage if machine does not have the ability to use FOPENA to create the file so that will not work. The RS232 will not allow screen display but will allow the TOP file for the variables to be transferred back and forth to the CNC. This will accomplish what you want.
    You may want to consider the screen fix as well. There are companies such as Invision that can fix your screen or replace it with a new lcd style screen.
    (262) 521-2000
    There is also a brightness adjustment inside the control for your crt that may help you see better. Have you tried adjusting it?
    Although it will work, GET PUT READ WRITE will be the difficult way to accomplish I/O of variables. Use DATA INPUT/OUTPUT.
    It would also be possible to put the variables inside the program like kitten says and transfer the entire program with variables back and forth.
    Best regards,
Page 2 of 2 12
  1. Activate macro variables common #550 to #999
    By VicEd in forum USA Club House
    Last Post: 12-07-2017, 08:13 PM
  2. Replies: 12
    Last Post: 02-14-2011, 12:34 AM
  3. Fanuc OM - M99 Clears Common Variables
    By ED209 in forum Fanuc
    Last Post: 07-11-2009, 07:31 AM
  4. Common Variables
    By viorel26 in forum G-Code Programing
    Last Post: 10-02-2007, 10:09 PM
  5. Need help with IF ,THEN,AND GOTO USING COMMON VARIABLES.
    By XRACERJB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-31-2007, 02:08 PM
