585,761 active members*
4,128 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Access data (common variables)
Page 1 of 2 12
Results 1 to 20 of 22
    May 2018
    74
    Hello All,
    Something just comes across my mind so I decided to post it here to see you can give me your input.
    Is there any way to access data. I meant read and write all common variable data from the machine via PC? If yes what is the program language are we going to use??
    We have OKUMA OSP500L, 5000L. Old machines
    Jun 2015
    4154
    Re: Access data (common variables)
    hy nodochau if you wish, i will share soon such a program, that once executed, will create a file with common variables values
    that file, if you wish to send to a pc, you need a dnc , mt connect, or something for file transfer
    thus, i can help with creating the file, but i can't help you with file transfer
    if i may, why do you wish to record those values ? kindly
    May 2018
    74
    Hi deadlykitten,
    I came across the API application on gosier website but that app works on new okuma machines (window base) only. It is a great app to send, read and write data from pc to machine.
    So I think there should be some ways to access machine data and write the data to the machine via pc with older models. Our machines are old but still working great.
    Sometime the screen is too blurry so its hard to see ).
    Quote Originally Posted by deadlykitten View Post
    Jun 2015
    4154
    hy nodochau api is not an app ... is a library of programing procedures
    api can be accesed via programing, so to create custom applications; api, on its own, is not going to do a thing
    if installed on the controller, together with a custom app, it can create a file with custom variables values, but that file will be located on the cnc, thus it won't be sent to an external pc
    to send the file to a pc, or to write the file to a storing device <> osp hdd, then is needed to change the output path, inside the custom app
    yup : create the file ( with common variables values ) by using a *.min program, and after that send the file to a pc, using a file transfer software
    again, i can help you with the *.min file, but i can't help you with the file transfer
    also, if i may, common variables are not machine data, but osp data; machine data includes axis data, cinematics, efforts, etc, something related straight to cutting/operating
    there is nothing like an old bone
    but why do you wish to export those values ? you edit them inside the machine, why bother to record the values ? kindly
    May 2018
    74
    I want to edit them outside the machine since I don't see anything on machine screen. Is it crazy :=))
    That is why I record - transfer - edit - transfer back to machine.
    Jun 2015
    4154
    i guess you need to fix that monitor do you have a file transfer software ? do you transfer files to/from the cnc ?
    Apr 2009
    1262
    Should be able to do what you want using get out read write functions over your rs232 port.
    Experience is what you get just after you needed it.
    May 2018
    74
    Sounds good OkumaWiz.
    Can you show me what do I need?
    Apr 2009
    1262
    See the attached section from the programming manual:
    You will still need a cable to tie to your PC thru the RS232 if that is what you are looking to do.
    Best regards,
    Attached Files Attached Files
    May 2018
    74
    Thanks a lot OkumaWiz. I found the chapter in my Manual Book and it was exact what you gave me.
    I am confused about the text file which is written so that the data can be transferred to the machine. Where is the text file is supposed to be saved into? I think the PC.
    I have to have the DNC software that I can get it but the text file in the sample at page 354 made me confusing. That text file has to be saved and updated some where so that the machine can get the update...
    A Compensation Yes/No = 1 Offset No. = 3 OX = 0.02 OZ = -0.31
    1 5 10 15 20 25 30 40
    (a) (b) (c) (d)
    Apr 2009
    1262
    You are not actually creating a file and no additional software is needed for the machine. When you read from the pc a short text string is sent from the pc and then stored in the read buffer. Then you get data and store it to common variables. As you describe the first character you get may be yes/no. The next set of characters may be an Offset or other data that you store in the next Variable. Continue parsing the string of data until finished.
    Then process your variables in the program as needed.
    Put and write are used to send data back to the pc in similar fashion.
    This is commonly used to communicate with a post process gauge.
    May 2018
    74
    Quote Originally Posted by OkumaWiz View Post
    OK. It sounds a little bit clearer. "When you read from the pc a short text string is sent from the pc and then stored in the read buffer" you meant the machine (program) reads the short text string from the pc? I guessed. So we have to create that short string in Notepad under CNC or txt? And the program will read the string as soon as you open Notepad app and type the string in? Then after the program processed we will get all data from machine put in the pc (Shown on screen of pc) if we want? If it is true then it is very awesome though. I definitely will give it a try.
    Jun 2015
    4154
    yes, very nice questions nodochau, you are definetly on the right way
    please mr wizard, using 232 is only to transmit data, not also files ? for example, if the file is created inside md1, can it be transfered to the pc with 232 ? or 232 only sends the write_buffer, which is saved on the pc ?
    i see no reason to use 232 to transfer content, whose size is lower then osp program capacity
    of course, i believe this will work for nodochau, but is there a method to transfer a file while the machine is running ? 232 seems too intrusive / kindly
    Jun 2015
    4154
    hy nodochau, actually the machine will receive a buffer, and that buffer contains alphanumericchars : 0-9 az AZ
    like this, content may be sent to / from the machine
    buffer size is circa160chars; so if a file has:
    ... <160chars, it will be sent in one shot
    ... >160chars, it will be sent in small portions of 160chars, thus there will be small packages, divinding the content into smaller sizes, that can be managed by the controller packages will arrive one after the other, so some " hand shake / parity " parameters will need to be set, to avoid the case where packages will rush one over the other
    you dont have to think about that ' short string '; i mean you can simply create a file on the pc, and it will be breaked automatically into smaller packages, during the transfer sequence
    no, not quite : let's say that you have the file tmp.txt on the pc, and it has one line : " 123 456" ( 6 blanks, 6 chars )
    program inside the machine will be similar to this :
    FOPENA tmp.txt
    READ 0 ( open 232 chanel )
    GET , 3 ( read 3 blank chars )
    GET V1 , 3 ( read next 3 chars, thus read 123, and initialize V1 with 123 )
    GET V2 , 3 ( read next 3 chars, thus read 456, and initialize V2 with 456 )
    CLOSE 0 ( close the chanel )
    i am not sure, since i never used 232 / kindly
    May 2018
    74
    hy nodochau, actually the machine will receive a buffer, and that buffer contains alphanumericchars : 0-9 az AZlike this, content may be sent to / from the machinebuffer size is circa160chars; so if a file has:... 160chars, it will be sent in small portions of 160chars, thus there will be small packages, divinding the content into smaller sizes, that can be managed by the controller packages will arrive one after the other, so some " hand shake / parity " parameters will need to be set, to avoid the case where packages will rush one over the other you dont have to think about that ' short string '; i mean you can simply create a file on the pc, and it will be breaked automatically into smaller packages, during the transfer sequenceno, not quite : let's say that you have the file tmp.txt on the pc, and it has one line : " 123 456" ( 6 blanks, 6 chars )program inside the machine will be similar to this :FOPENA tmp.txtREAD 0 ( open 232 chanel )GET , 3 ( read 3 blank chars )GET V1 , 3 ( read next 3 chars, thus read 123, and initialize V1 with 123 )GET , 3 ( read 3 blank chars )GET V2 , 3 ( read next 3 chars, thus read 456, and initialize V2 with 456 )CLOSE 0 ( close the chanel )i am not sure, since i never used 232 / kindly
    So the filename.txt is saved in pc already and I have to open it up so that the data can be transferred to machine, right?Example my file has one line and there is one space between the two values2.1252 2.1253 And I want to set v1=2.1252, v2=2.1253How is the program written.
    Jun 2015
    4154
    maybe something like this :
    Code:
       FOPENA tmp.txt
       READ 0
       GET V1 , 6
       GET    , 1
       GET V2 , 6
       CLOSE 0
       // file content : '2.1252 2.1253'
    Jun 2015
    4154
    hy nodochau, i see you started digging about how to use 232; good luck with that, i can't help with 232
    i just wanna say this : if you modify just a bit the program from previous post, replacing '0' with 'A', like this :
    Code:
       FOPENA tmp.txt
       READ A
       GET V1 , 6
       GET    , 1
       GET V2 , 6
       CLOSE A
    then the file can be located not on a pc, but on the machine, in MD1 folder ( or whatever is your main system device ), thus you can read directly from a file located on the machine
    like this, there is no longer needed to tranfer the file content from the pc in real time
    this method has the benefit that it does not require to 'pair' the pc with the machine, but it requires a method to transfer the file passively; i work like this, and main advantage is that the machine can run whatever program, and the files may be transfered while the machine is running
    is better to be able to manage files regardless of the cnc state ( executing a program, waiting, etc ) / kindly
    Apr 2009
    1262
    Got thinking about this some more and I think there’s an easier way.
    Your vintage of machine should have the DATA PIP function on it.
    With this it’s possible to punch out machine settings for backup purposes. You can also read back in the backup to set the data. This will create the variable “text file” that you are after.
    Commands would be as follows:
    From parameter mode:
    DATA PIP
    PUNCH
    CN0: VAR.TOP,P2
    Prepare PC to receive file using up/download software
    WRITE
    This will create a text file of your variable on the PC that you can edit.
    Make your changes and then pull it back in using DATA PIP as follows:
    DATA PIP
    READ
    CN0: VAR.TOP
    WRITE
    Send the file back from the PC.
    Look in your operation manual for more details on DAT INPUT/OUTPUT.
    I use it for setup backups all the time and it should work for what you want as well.
    Best regards,
    Jun 2015
    4154
    hello nodochau, i also have been thinking about this ... so you wish to read / load the custom variables from the pc, but you don't have a conection between the machine and the pc
    also, your screen monitor is not ok, you can not see ok, but you use variables inside your programs ...
    if you allready use variables inside the programs, why do you wanna save them to the pc ?
    so, your screen is ok sometimes, but not always ? and when it is broken, your only problem is reading the variables ? there is a missing puzzle piece in all these / kindly
    hi mr wizard, what about replacing "datapip"+ sending to the pc, with a *.min that saves the file, with variables, on the machine ? in both cases may be needed to rename the file, only that using a *.min to save all the variables does not require a conection to the pc / kindly
    May 2018
    74
    Cool Re: Access data (common variables)
    hello nodochau, i also have been thinking about this ... so you wish to read / load the custom variables from the pc, but you don't have a conection between the machine and the pcalso, your screen monitor is not ok, you can not see ok, but you use variables inside your programs ...if you allready use variables inside the programs, why do you wanna save them to the pc ?so, your screen is ok sometimes, but not always ? and when it is broken, your only problem is reading the variables ? there is a missing puzzle piece in all these / kindly hi mr wizard, what about replacing "datapip"+ sending to the pc, with a *.min that saves the file, with variables, on the machine ? in both cases may be needed to rename the file, only that using a *.min to save all the variables does not require a conection to the pc / kindly
    Hi Deadlykitten,I don't want to save all variables into pc. I just want to see them in the pc screen if we can out put the data. And If I can see them then I want to know are we able to put the data from the pc back to the machine.I just ordered the cable and study some parameters to hook the pc up to the machine. Don't know yet but will see. Regarding your code so I think what need to be done are: (If I hook the pc up successfully)Create a text file name test.txtProgram read/Write...Run the code .. so The question is the file needs to be opened on the pc screen? Sorry if it is a dump question
Page 1 of 2 12
  1. Activate macro variables common #550 to #999
    By VicEd in forum USA Club House
    Last Post: 12-07-2017, 08:13 PM
  2. Replies: 12
    Last Post: 02-14-2011, 12:34 AM
  3. Fanuc OM - M99 Clears Common Variables
    By ED209 in forum Fanuc
    Last Post: 07-11-2009, 07:31 AM
  4. Common Variables
    By viorel26 in forum G-Code Programing
    Last Post: 10-02-2007, 10:09 PM
  5. Need help with IF ,THEN,AND GOTO USING COMMON VARIABLES.
    By XRACERJB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-31-2007, 02:08 PM
