585,744 active members*
4,470 visitors online*
    Jan 2013
    7
    New Control Build with Mach 4 - Flooding control
    I am currently doing a full rebuild of my control gear for my 6090 CNC and upgrading to MACH4.
    During testing (in simulator mode) I noticed that the flood & mist control don't turn off when emergency stop is active.
    Is this normal behavior? Would have though a E-Stop would shut down everything.
    Going to use flood (M8) to control my dust extractor so want it to shut down when E-Stop is hit.
    Nov 2013
    4361
    Re: New Control Build with Mach 4 - Flooding control
    Mach4s Estop stops all axis motion and spindle. If you want other items to stop or behave in some specific fashion add the appropriate script
    to the <Estop> button.
    Craig
    Jan 2013
    7
    Much appreciated Craig. Will put my scripting hat on and go digging.
  1. Need help with VFD control through Mach 3
    By kathiki1 in forum Spindles / VFD
    Last Post: 04-08-2018, 06:43 AM
  2. THC for Mach3 - full external Z control vs Mach Z control
    By Beefy in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-28-2015, 10:45 PM
  3. Best way to control GS2 VFD with Mach
    By brian257 in forum CNC Machine Related Electronics
    Last Post: 05-10-2014, 10:56 PM
  4. Configuring Mach 3 with my control kit.
    By JackWilliam in forum Mach Software (ArtSoft software)
    Last Post: 12-12-2012, 11:27 AM
  5. MACH 3 control
    By ploughex in forum Machines running Mach Software
    Last Post: 06-14-2011, 02:10 PM
