585,728 active members*
4,174 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > Issues Cutting Thin Materials - Proma Compact THC Controller SD
    We have a Premier Plasma CNC Table with a Miller Spectrum 625 X-treme attached to it and a Proma Compact THC Controller SD. Everything is working fine except when cutting thin materials or materials that are warped. Our issue seems to be that once the head’s height is set at the beginning of a cut, it doesn’t adjust if the material is unlevel or warped through the cut and it stops cutting.
    My main question is, can someone confirm that the Proma Compact THC Conntroller SD is capable of auto-setting the head’s height while cutting? If not, what THC controller do I need in order to get automatic touch sensor.
    Jun 2009
    251
    Quote Originally Posted by fsdolphin View Post
    Proma SD needs to be configured for your drives, as in you jave to set the steps for mm or inch. Most probably you have that set to low so it can not keep up with the change in voltage.
    Re: Issues Cutting Thin Materials - Proma Compact THC Controller SD
    @tommylight - Sorry I never saw your reply until now. Would you mind elaborating more on how to configure the Proma SD? Thanks
  1. Proma 150 thc issues??
    By Chris37 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-16-2018, 10:56 AM
  2. Thin stainless steel laser cutting machine for metal and non-metal materials
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2016, 03:45 AM
  3. thin -plastic- materials
    By LaserMark in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2015, 12:46 PM
  4. Work Holding for thin materials
    By rwskinner in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-17-2013, 08:14 PM
  5. What to use when cutting thin materials ?
    By twocik in forum Benchtop Machines
    Last Post: 04-07-2008, 09:49 PM
