585,605 active members*
3,258 visitors online*
Results 1 to 1 of 1
    Come checkout what I do with ABS!!!
    New here to pick brains and share my ideas!!
    I build ABS mining equipment on my Thermoforming machine, and in the process of building a new machine.
    old machine is a 2 by 4 with a overhead heater, air cylinder plastic frame lift system.
    My new design is a 4 by 4 shuttle design, with mold lifting from the bottom up!!
    you can see my old machine run at my youtube, Spikes Prospecting Equipment is my channel
    www.spikesprospecting.com is my website, where you can see the things I have been building the past 2 years, on my 2 by 4 homemade machine. I am updating my existing machine to a 4 by 4 to increase production, accuracy and easier on my old retired body. Once this new machine is done, I plan on building a % by 5 CNC for cutting my molds from a solid blocks of wood!! Use some epoxy molds, but most are still in wood, always looking for options!!
ID:	422875http://<iframe src="https://www.face...rue"></iframe>
    Thanks Spike, welcome ideas and questions!!
    Www.spikesprospecting.com<br />Owner/ designer
