585,758 active members*
4,310 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > FULING VFD inverter 5.5KW, 3 phnase
    Aug 2013
    7
    Hello Dears,
    need I to use power EMI filter for 3-phase 400V FULING VFD inverter 5.5KW, ? And if so can you give me some advises what model should it be
    15362
    Re: FULING VFD inverter 5.5KW, 3 phnase
    Quote Originally Posted by smart81bg View Post
    Hello Dears,
    You have to know how many amps the Motor /Spindle you are driving and then you can work out what you need, most look up what the max input current is for the VFD Drive and then size the Filter to suit that
    Mactec54
  1. Fuling Inverter DZBSeries
    By gerardo.pellice in forum Phase Converters
    Last Post: 08-09-2022, 05:27 PM
  2. Fuling inverter DZB300 or DZB200
    By bivegele in forum Phase Converters
    Last Post: 10-21-2021, 03:19 PM
  3. SEtting Fuling DBZ200 Inverter
    By regpugh in forum DeskCNC Controller Board
    Last Post: 03-28-2014, 11:51 AM
  4. Fuling Inverter spindle speeds and feed rates
    By alanstclair in forum Chinese Machines
    Last Post: 07-17-2012, 11:21 PM
