585,719 active members*
4,054 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD with Standard 3ph motor
    24220
    Article in this months Electrical Business on using VFD and standard motors.
    http://magazine.ebmag.com/publication/?m=46123&l=1#{%22issue_id%22:592928,%22page%22:26}
    Al.
    Albert E.
    15362
    Re: VFD with Standard 3ph motor
    Al.
    Just reinforces what I have been saying for years
    Mactec54
    Sep 2005
    1740
    Nothing new, manufacturing has been using VFD's on standard 3 phase motors for years, the commercial HVAC/R industry also on air handing units for fan speed control same thing. Heck I was retrofitting units 30 years ago. All the wiring was in metal conduit, controls usually with 4-20 ma or 0-10 vdc. Big energy savings on VAV box systems.
    24220
    I to have been using VFD's since the late 80's, all were standard AC motors also there was no 'VFD' cable out there then.
    The earliest motor fitted was on a 1954 machine retro fit 30' bed planer.
    Al.
    Albert E.
    Sep 2005
    1740
    The earliest motor fitted was on a 1954 retro fit 30' bed planer.
    Al.
    Al I can not remember the first one we put in, but yes no special motors no special cable and we ran all the power wiring in conduit as you did also the flexible motor end was Sealtite with the added grounding strap inside. We knew enough to use shielded wires for the control feed outside the enclosure. Shielding soldered and crimped, The old motors with lots of copper and steel worked great on those VFD's.
  1. Standard or Pro
    By kemerick in forum Avid CNC
    Last Post: 01-30-2015, 09:13 PM
  2. Help! Non-standard encoder on Panasonic MINAS servo motor
    By jdgoguen in forum Servo Motors / Drives
    Last Post: 12-20-2014, 04:19 PM
  3. Bridgeport spindle RPM calculation for non-standard motor RPM?
    By PhoenixMetal in forum Bridgeport / Hardinge Mills
    Last Post: 07-18-2010, 09:13 PM
  4. Motor Couplings - Metric to Standard
    By Jgeist in forum Want To Buy...Need help!
    Last Post: 04-19-2010, 07:12 AM
  5. MR-S DRIVE & MOTOR STANDARD SETTINGD
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-29-2008, 05:33 PM
