585,975 active members*
4,971 visitors online*
Results 1 to 6 of 6
    Jun 2013
    454
    Micro Steps question please...
    Hey G'day people,
    I have a few of these stepper motors, I bought them from Homann quite a while ago now, I am using some TB6600 drivers (just finishing up my new control box).
    The TB6600 comes default dip switches s1 s2 s3 are off off off and s4 s5 s6 are off off off (this is fine its set for 3.5 to 4amp).
    Trying to find more on the stepper motors as to how many micro steps should I set the dip stitches s1/2/3 to. Default it is 32 micro and pulse/rev is 6400.
    If anyone has one of these stepper motors would love some help or the math/how to work out if there is a calculation to figure out the micro step setting I should have.
    Cheers,
    Steve
    Model Number: 24H290-35-4B
    Specifications
    Size: Nema 24 (Size 60)
    Phase: 2 Phase
    Step Angle: 1.8 Degrees
    Voltage: 50V Max
    Current: 3.5A
    Resistance: 1.0ohm
    Inductance: 2.8mH
    Holding Torque: 387 Oz-in
    Dual Shaft
    Bipolar 4 Wire
    Jul 2018
    6337
    Re: Micro Steps question please...
    Hi Steve - As a general statement here goes. 1) The more steps the smoother the motor operates but depending on some factors it may not reach high speeds Some drivers have better response then others to mid range vibrations and high speed back voltage issues 2) You have a 1.8deg per step motor with probably 5% tolerance. This means it's not much point going past 4000 microsteps as this is about the same as the mechanical accuracy. 3) so depending on your application positioning or movement you pick the microsteps to suit. If its a router for instance not much use going past the 4000 microsteps. So 5% tolerance is =1.8*0.05 = +/-0.09degs. 4000 microsteps =360/4000=0.09degs so if you picked 8000 usteps you would have a theoretical step of 0.045degs but the motor could only achieve 0.09deg so no point in using over 4000 usteps for positioning purposes. But if its for smoothness say a camera dolly then use as many as you need to get the smoothness you want. Oh and drive at the highest voltage possible always better for steppers but only set the current at what you need to stop overheating or set at correct current.....Cheers Peter S
    The motors specs are mostly irrelevant.
    Most people use 1/8, or 1/10, which give you 1600 or 2000 steps/rev.
    Jun 2013
    454
    Pete G'day mate.
    Thank you for the detailed explanation, that made a lot of sense. I actually understand what its about now ty muchly.
    So not much point leaving it at default which is 32000 lol ok..
    I appreciate your time...
    Thank you too Ger!!!
    May 2015
    686
    In terms of positioning, its not much point going past 10x but higher values will help improve smoothness. But also the maximum frequency your controller can operate will limit what you can get away with.
    I can get away with 25x micro stepping but I am using hardware stepgens (linuxcnc and Mesa 7i76e ehternet card) . Its a while now since I worked it out but I think I was up around 90 kHz at max speed but a parallel port might be limited at 50 kHz.
    And I'm in Brisbane
    Rod Webster
    www.vehiclemods.net.au
    Jun 2013
    454
    Rod G'day mate,
    I had to laugh I'm sorry being in Brisbane may have an effect on how your machine operates LOL....
    Thank you for your input, I have an AXBBE ethernet controller so I should be ok, I've set it to an appropriate step will see how that works once I finish building the box. I only have the UCSB breakout board to wire in and I'll be ready for a test run.
    Cheers and avagreatday.
    Steve
  1. Configuring Micro Steps for Leadshine DM1182 Driver
    By jacoe2222 in forum Leadshine
    Last Post: 03-24-2017, 02:52 AM
  2. Micro steps info needed
    By acourtjester in forum Linear and Rotary Motion
    Last Post: 04-04-2013, 02:29 PM
  3. Linistepper 32nd or 64th micro steps?
    By Kingjamez in forum Open Source Controller Boards
    Last Post: 03-19-2008, 06:35 AM
  4. Taig Micro Mill 2000 steps per unit
    By JV11 in forum Linear and Rotary Motion
    Last Post: 09-26-2006, 01:13 PM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
