585,967 active members*
4,116 visitors online*
    Enquiry about CNC router
    Hello!
    Is there a necessity for the size of the ball screw to match with the model of the linear profile guide?
    For example if the ball screw dia is 12 mm, should the linear guide rail be of 12mm wide too?
    Apr 2004
    5737
    Re: Enquiry about CNC router
    No. The ball screw needs to get thicker as it gets longer, or it will tend to "whip", which introduces resonance and shaking, and can distort the screw in extreme cases. Linear guides need to get wider if the loads increase, so a heavy machine used for cutting hard materials will need a wider profile rail than a lighter one used for soft materials.
    Andrew Werby
    Website
  1. 4th axis 360 CW & CCW rotation enquiry
    By marbles in forum Mach Mill
    Last Post: 03-18-2019, 11:14 PM
  2. SmoothStepper-Enquiry
    By leMaitre777 in forum Novakon
    Last Post: 10-13-2015, 10:59 PM
  3. Hello ....another rf 25 enquiry
    By rigman in forum Australia, New Zealand Club House
    Last Post: 07-14-2013, 11:23 AM
  4. welcome your enquiry on below machining services
    By cissy1981cn in forum Australia, New Zealand Club House
    Last Post: 04-20-2011, 07:22 AM
