CNC fiber laser cutting machine for sheet metal and tube. Take 2000w as example, maximum cutting sheet metal of mild steel 16mm, stainless steel 8mm, aluminum 6mm, brass 3mm, pipe / tube processing, L3000mm or 6000mm, Φ20-300mm.
Main Feature
1. Baiwei self-design Closed Type Plate & Tube Laser Cutting Machine, save cost and space.
Large surrounded structure improves using security;automatic collection system of smokes and dusts is environment friendly; intelligent monitoring system reduces accident rate, making us enjoy beauty and health in cutting process;
3. This model is available for square tube, circular tube, oblate tube, and plane cutting in one, with multifuction and high practicality.
4. Gantry structure and dual drive, Germany imported rack & pinion drive system. Excellent cutting performance and stability.
5. Self-centering system ensures stable process of conveying pipes, to ensure high accuracy and high quality of products.
6. Saddle-shaped pipe type support beam with high precision calibration.
