Yea then you just get a box trow stuff into it, and then look all over for 1/2 hr. just for the things you put in the box and forgot. I think that is all to familiar to some.
Joe
Joe
Well the machine is getting to a point where it is harder to climb over the machine to work on it and also almost ready to move to put it into its place. I went to Harber Freight and got 4 screw jacks for 15.99 each and installed them , I need to put two more diag. bracing on the sides to make sure the machine will not flex, As it is not I can push it with my weight about 195 lbs and it does not flex, so with two more pieces i'm sure it will be good to go, And also will place some cross pieces to make a sheck for stock pieces and storage.
Hi Joe
In post 30, your picture shows assembling the unit on some kind of greyish base material. I assume this is something you use to keep things flat / square. Is this an epoxy floor area, or that special wall board used in bathrooms ?
That is just an old rug i use for the shop area.
I just bought a 360 deg. laser level.
http://www.blackanddecker.com/Produc...ProductID=6463
Big lots has it for 30.00 sells on amazon for 133.99 a great deal.
I will use it when i have the machine in place and will be able to quickly level it up before i surface the top wood supports to ensure a level bed.
Joe
Got the machine moved into its location, leveled with the Jack screws and used some angle for the adjustment feet.
Also got the walls up for the 8'x8' room it where it will sit (still have enough room to park truck in garage, All the walls are up except the rear, waiting for the belts to arive tommarrow from sdp-spi, to couple the two leadscrews together, to make sure the Gantry stays square incase one motor misses steps hoepfully the other motor will help it along. in one of the pictures you can see the shelf the computer and driver boards in a computer case.
Also on the otherside i have enough room for theDelta dust collection system, with the trash can seperator
Joe
before placing the cutting bed top I milled the wood rails which were screwed from the bottom into the Cross beam stuts, this makes sure the top is parrallel to the gantry.
Joe
Impressive looking.
hi Joe-- very nice machine....
On my Unistrut that i have, i've noticed some loosening of the uni-Tee nuts - (those silly rectangled ones that only turn one direction) - just a heads up. loctite, or tack welding (if you tack it- remember welding galvanized isn't recommended, toxic gas and such, ventalation very important)
Hey Joe,
I really like what you're doing with the 4x4. I curious though, is it stronger/stiffer then the Joe2006? I really like your Joe2006 and might possibly start building a version. Before I do, I'd appreciate knowing if your 4x4 Y-axis is stiffer then then the Joe2006. Any thoughts?
Joe,
Those look like some pretty heft extrusions. What size are they? They look HUGH!
Bill
The first cut on the machine was to make its own Dust Collection skirt.
I was very impressed with the quality of the cut, could not really see any chattering. Here are a couple of pictures of the center hole cutouts so you can see the quality of the cut and they are untouched straight out of the machine.
Joe
Video?????
Jason
Howdy Joe
Video sounds good.I second the motion
More then likly answer one of my questions.
Is the attachment floating ? how is it attached? and last but not least. How much Z-axis cutting height do you lose with the ATC ?
Kent
