584,862 active members*
5,386 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Aug 2013
    189
    Re: NCStudio OR Controller
    Quote Originally Posted by shearder View Post
    Not sure if I want to walk but I guess I could use the Bentley...
    BUT sounds good. My misunderstanding was that those with a lan connection were controlled over a literal network. If plugged direct to laptop does one need a crossover cable?
    This seems a good idea!!
    Sent from my SM-N960F using Tapatalk
    Any network cable will do, both direct or crossed, the ethernet cable is just the way of communication like your current LPT but faster. I use Mach3+ESS for 5 years now and never had a problem.
  2. #22
    Sep 2009
    277
    Quote Originally Posted by vakeiros View Post
    Thanks for that info. I will look intro this.
  3. #23
    Jun 2018
    362
    Be careful with that. Older network interfaces with RJ45 connectors may not auto-detect a cross-over cable properly. Cheaper cables may not have enough wires or be incorrectly wired. If the connection is directly between two NIC cards, this can be frustrating.
    It's also a trap sometimes with USB cables that are data or power only versus data and power and wondering why you can't transfer data between a PC and/or charge a mobile phone.
  4. #24
    Sep 2009
    277
    Quote Originally Posted by he1957 View Post
    Thanks for that
  5. #25
    Apr 2005
    304
    If you have a laptop that is from era of Methusalem, then you might be out of luck that it has autodetect possibility.
    Any decent laptop will autodetect the cable type.
    BTW Bentley is overkill for short hops, better try Yugo
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  6. #26
    Sep 2009
    277
    Quote Originally Posted by ZASto View Post
    Thanks. I'll have a descent laptop.
    Bentley is never overkill
Page 2 of 2 12
  1. NCStudio help.
    By bfamily in forum Chinese Machines
    Last Post: 10-13-2017, 02:29 PM
  2. Weihong ncstudio CNC controller card Driver help!
    By xchiazyx in forum Commercial CNC Wood Routers
    Last Post: 10-04-2016, 02:41 PM
  3. ncstudio v9
    By crazy_dreams in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-12-2016, 03:11 PM
  4. NcStudio help
    By Dhashna in forum Chinese Machines
    Last Post: 11-26-2013, 08:34 PM
  5. Ncstudio help
    By bachaar in forum Chinese Machines
    Last Post: 02-24-2013, 09:04 PM
