585,886 active members*
6,003 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Emcoturn 320 Fanuc O-T lost parameters
    Oct 2013
    Hello
    We have an Emcoturn 320 with Fanuc O-T control. Our machine was powered down for a while, upon restart we are greeted with alarms 417 and 427. One sheet inside the cabinet has some parameters listed but looks like we are still missing a lot more. We really want to revive this machine, the thing is solid. It was one of my favorite machines in the shop.
    Any and all help will be greatly appreciated!
    thank you
    Oct 2011
    38
    Re: Emcoturn 320 Fanuc O-T lost parameters
    I just bought a 320, I went looking for the sheet and hopefully a floppy backup disk. It was hard to find but behind the sheet in the plastic holder there was a disk! Maybe yours has the disk hiding in there. Just a thought.
    If not I think you call Emco USA and they maybe able to help. I'm not sure though.
    Then if you get back up and running I'm going to get the DNC Titan. Check them out. You can save the machine setup parameters to it as well as upload programs to and from it by USB drive.
    Oct 2013
    crclark
    I appreciate your response, unfortunately no luck on the disk for us. I called and emailed Emco, also no luck. They did not respond at all.
    I'll take a look at DNC Titan,
    thanks again.
    Oct 2011
    38
    Thats to bad they wont help, I've read that someone had luck with contacting the European Emco office. Emco Europe sent him what he needed. I have several Emcoturn 320 documents that I can send you if you need them.
    Hope that helps a bit
    Jul 2019
    Hi. I have the same machine. If you still need parameters, I have everything saved to disk. I'd be happy to assist. Let me know.
  1. Parameters lost Fanuc 0M
    By Milaublu34 in forum Fanuc
    Last Post: 06-12-2014, 01:15 PM
  2. Fanuc OMC - Lost parameters
    By Snowfly in forum Fanuc
    Last Post: 02-04-2014, 06:08 AM
  3. Fanuc O-M lost parameters
    By macperfo in forum Fanuc
    Last Post: 03-27-2009, 12:47 AM
  4. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
  5. Replies: 2
    Last Post: 02-08-2008, 09:00 AM
