585,930 active members*
4,023 visitors online*
Thread: setup
Results 1 to 6 of 6
    Feb 2009
    214
    setup
    I have a part that needs to be milled on the top and then turn to where the side faces up and then mill that side.
    I don't know where to look in help how to do a different setup.
    Where do I start to find out how to do this?, is this in the "stock wizard"
    David L. Aery
    www.hooksolutions.com
    Re: setup
    Use Work Coordinate Systems, it's mainly down to planning, reference points on work, stock or both, work stops and accurate set up though.
    Re: setup
    If your machined side doesn't lend itself to be being held in a vice for the second op you can machine a soft jaw which will support it derived from your part geometry or that of the machined stock saved from a completed simulation run.
    Feb 2009
    214
    Re: setup
    thanks, i found a video by Depoalo of "Multiple Machine Setups "
    https://www.youtube.com/watch?v=bVJYIbMmaVs
    this is what I was looking for, this makes it look easy but I am having some trouble with my orgin.
    I think I can get it now.
    Thanks!
    David L. Aery
    Feb 2009
    214
    Re: setup
    I actually got it to work:wee:
    David L. Aery
    Re: setup
    Excellent, that's great to hear!
  1. Dust collector setup,dust hood setup,power connecting
    By allencncrouter in forum Videos
    Last Post: 12-17-2018, 02:47 AM
  2. Replies: 0
    Last Post: 02-29-2016, 09:13 AM
  3. Replies: 3
    Last Post: 05-25-2015, 04:25 PM
  4. Replies: 1
    Last Post: 07-26-2011, 11:28 AM
  5. Replies: 13
    Last Post: 06-30-2011, 03:34 PM
