585,727 active members*
3,946 visitors online*
Thread: Chinese 6040
Results 1 to 6 of 6
    Mar 2018
    16
    Chinese 6040
    I'm building a spoil board and planning on securing it to the aluminum extruded bed. Does anyone know the size of the t-nut or slot nuts that fit? I measured and looks like 9mm, just not sure. I would like to use the slot nuts similar to the ones used by Incra tools.
    Apr 2019
    12
    Re: Chinese 6040
    I just used bolts, if you add a washer then the bolt can't turn and nylock nuts and washers on top, check my hold down board here. I really like the Rockler Track and hold downs
    https://www.cnczone.com/forums/chine...cnc-posts.html
    I believe these are the correct T Nuts.
    https://www.amazon.com/dp/B00JF7AIEM...v_ov_lig_dp_it
    Jan 2007
    626
    Re: Chinese 6040
    I bought mine from Radiospares a few years ago. Just had a look and can't see them. I have a pic somewhere.
    I'll post it if you like. Mine have a M6 thread.
    Edit: I found them!
    Attachment 423750
    Attachment 423752
    Mar 2018
    16
    Re: Chinese 6040
    Thanks, The Chinese 6040 uses a base of extruded aluminum and I finally found that it got 10mm grooves, so I got the square nuts from Amazon. They're 10mm M6.
    Mar 2018
    16
    Re: Chinese 6040
    Thanks so much. That's the slot nuts I was looking for. As I said earlier I was able to find these. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jan 2007
    626
    Re: Chinese 6040
    Quote Originally Posted by FGS View Post
    Thanks, The Chinese 6040 uses a base of extruded aluminum .
    No Worries. Yes, my machine is a 6040 so its bed is extruded Aluminium.
    I hope they do the job for you.
  1. My Chinese 6040 Experience So Far
    By kronick in forum Chinese Machines
    Last Post: 05-12-2018, 11:48 AM
  2. Help with Chinese CNC 6040 Router Please
    By Wdbilbo in forum Chinese Machines
    Last Post: 12-18-2016, 09:31 PM
  3. chinese 6040 cnc router
    By mrgame1988 in forum Australia, New Zealand Club House
    Last Post: 09-21-2016, 12:41 PM
  4. Chinese 6040 CNC Router
    By ecope in forum Chinese Machines
    Last Post: 11-02-2015, 10:07 PM
