585,585 active members*
4,072 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How to drive Analog Servo Input +/- 10V
    Apr 2007
    28
    What drives an Analog velocity signal in a servo amp?
    Can this be done directly from the computer, Program an IC?
    or otherwise?
    How do I deal with the motor encoder outputs to drive an analog velocity signal from the computer?
    Hope someone can help?
    Thanks in Advance
    24220
    To use a PC you generally need a motion card or other with analogue output. The loop is closed back to the motion card via the cards encoder input.
    If you use a software based control like mach etc, the signal to the drives is step & direction through the parallel port, so if you have analogue drives you need a S/D to analogue conversion I believe if you search here for Pixie it will show up.
    For an example of a closed Motion card look on the Galil Motion site.
    Al.
    Albert E.
  1. want to built servo drive(analog and digital)
    By grebator in forum Servo Motors / Drives
    Last Post: 04-03-2007, 04:29 PM
  2. connecting 4-20mA device to analog input
    By Karl_T in forum CamSoft Products
    Last Post: 09-02-2006, 06:52 PM
  3. Pixie Step/Dir to Analog Servo Controllers
    By KTP in forum News Announcements
    Last Post: 03-06-2006, 05:12 PM
  4. Need input for servo control systems
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-31-2005, 05:45 PM
  5. A Homemade Servo Driver Input Request
    By teilhardo in forum CNC Machine Related Electronics
    Last Post: 04-19-2004, 10:05 AM
