Although I'm still only milling in virtual reality, I'm making some progress. One problem I will run into in real life is how to set machine zero. I have an idea, but I'd like to know if it is possible / logical.
My end switches are in series per axle, not in total. So I have a separate signal per axle. The X0 Y0 Z0 is in the middle of my table (because I want it to). Now I want to do the following. I tell the machine to G00 to X1000 Y1000 Z1000, which are all 'a bit' outside of the machine's range. So, after reaching it's X limit switch, it stops the X movement but Y and Z continue. Then Y stops, then Z. (or in any order, depending on where you start). Now I calculate / measure where the router stopped, compared to the zero point. I then overwrite the DROs of the axle positions with these figures and presto, it knows where the zero point is. Next time I power up the machine, I run in into it's limit switches, overwrite the DROs and Im' ready to go. Only when I change routerbit I need to reset the Z value, but otherwise I think I should be OK.
Questions:
Does this all make sense?
Can Mach3 continue G00 in the two other directions when the first limit switch has been tripped?
Hugo
