I'm creating a Post processor for our Techno machine, we just added a 4th axis to it. So I'm having a couple of issues that I'll spell out, hopefully someone will have some insight.
1-Problem:
The 4th(A) axis has a 50:1 transmission and there for needs to be set to around 10000 for the feed rate to keep up with the rest of the machine running at 150 feed rate. With out setting this it takes the A axis 1.5 minutes to rotate 1 full revolution. Too slow.
1-Hopeful Solution:
Is there a way to set the feed rate different for XY, for A & for Z?
2-Problem:
When I post my code, to just turn a cylinder blank the code has the Y & Z axes are moving from -3 to 3 but they shouldn't move at all. All that should happen is the A spins, the X moves.
2-Solution:
Not sure, does the TRANSFORM setting have something to do with this? *TOOLPATH OUTPUT* is set to TRANSFORM. But I don't know what it should be set to if not this. There isn't anything in the help about the proper setting if not set to TRANSFORM. Or other options under that setting.
3-Problem:
When I create a stock model and simulate my toolpath the stock model is orientated 90 to my part and the cut path. Not sure what this is related to, or if it affects the post. So when I simulate the toolpath rides along the X as it should and shows my part there. But the Stock is lengthwise along the Y and spins around hitting everything.
3-Solution:
Ok So it looks like this has to do with my machine setup for MadCAM. I have a 4 axis machine selected, but it still once the 5axis rotation parameters set. But I don't have any so I don't know what to do.
Thanks everyone.
-Ryan
