as the title says, im getting HUGE programs out of BobCAD for what should be simple machine paths, from what i can tell, most movements are broken into four lines of code at minimum, some are more. does anyone have a solution for this? V30
I think I saw this this video the other day I’m new to Bobcad. It was the arc segments being too high I believe thousands of little moves!
ive got my arc segments set at .0007" , the funny thing is, that its doing it on straight line movements as well....
What Post Processor are you using??
If using the BC_3x.BCPST then open in Notepad and have a look at the lines shown below and check the settings, may be something there that will help.
319. Break arcs with radius larger than? 0.01
320. Arc segment breaking tolerance? 0.001
321. Line segment maximum length? 999.99
550. Break arc segments into lines (Make sure to adjust value in block 319)? n
551. Break line segments into smaller lines? n
552. Support only G17 Arcs? n
553. Break helix into lines? n
554. Convert small arcs to lines (arc length to be specified in block 555.)? n
555. Small arc length to break? 0.0025
Regards
Rob
im using a factory loaded post processor: fanuc 31i
Jay Dizzle what toolpath are you using? What does the part look like?
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
