The 2017 simulator version I had been using finally came to an unusable crawl - I assume due to Windows updates, so I attempted to update - both Rhino/MadCAM 5 & 6. The simulator in the 2019 MadCAM versions has the draw stock option disabled, am I correct? All the other options work fine.
I then downgraded to the latest 2018 versions. I ran in Windows 8 compatible mode after running the Windows compatibility troubleshooter. Everything works fine except that the cut area is no longer shown using the bit color (as opposed to staying with the stock color) making it difficult to see what has been cut and by what bit. Is it possible to get this feature back?
Also I think it would be great if the draw stock option can be put back into the 2019 versions (20190605 for MC6 & 20190514 for MC5). It will probably run OK for me now in Windows 8 compatibility mode.
Thank you.
