585,926 active members*
3,981 visitors online*
    Aug 2008
    12
    Ohmic probe interfacing
    I am not sure what forum to put this in, because it is in between the torch and the control electronics. What do people do with respect to actually hooking the shield on the torch up to the BOB input pin when implementing ohmic probing? It seems to me that there is potentially bad things that can happen that might allow the negative voltage on the plasma machine power supply make it to the input pin. How about isolating the pin with a relay during cutting? External zener? I am thinking it would be good to have something that is less expensive to replace than the BOB. I cannot find any discussions addressing this, nor have I ever ran across one. Does anyone have thoughts or inputs? Thanks!
    Sent from my iPad using Tapatalk
    May 2015
    686
    Re: Ohmic probe interfacing
    Try the circuit in this article I wrote for the LinuxCNC documents
    Plasma Cutting Primer for LinuxCNC Users
    You need two pins as we keep the power totally disconnected unless we are probing.. Works a treat! Good luck
    Rod Webster
    www.vehiclemods.net.au
    Aug 2019
    Hi . Dear I have hyd thx with 125A hypertherm . HYD got E3 error.can you tell me what is this about ?
  1. ohmic sensing
    By stirling in forum CNC Machine Related Electronics
    Last Post: 07-31-2017, 10:22 AM
  2. ohmic how to ?
    By lkigam in forum CNC Machine Related Electronics
    Last Post: 08-07-2016, 11:03 PM
  3. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  4. Ohmic Sensor - HOW?
    By gzm.pepe in forum Waterjet General Topics
    Last Post: 07-31-2012, 11:59 PM
  5. Ohmic sensor
    By Bobbyr70 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-03-2011, 04:38 AM
