586,000 active members*
4,772 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > DDX Easywood and masterwood
Results 1 to 1 of 1
    Jul 2019
    Hi all
    We have a masterwood project series router machine with ddx easywood for programming. It is a cnc flat bed router.
    The question is about easywood. We need the panel to be tilted facedown in-between a programme inorder to machine both faces, so how to give that command line in side the programme. A command to park and release vacuum.
    Inside the ddx kits there is a pause option but I need pause+vacuum unblock.
    Or if someone know what is the Mcode for vacuum on and off.
    Thanks.
