584,812 active members*
5,395 visitors online*
Page 3 of 3 123
Results 41 to 51 of 51
  1. #41
    Aug 2016
    132
    Re: Let's build some ISO20 spindles
    An oil chiller is not an absolute requirement for high speed spindles. Fanuc RoboDrills come with 24k spindles (ceramic, gease packed bearings) that are air cooled.
  2. #42
    Jun 2007
    3891
    those 24k fanuc spindles spindles also have low preload and a relatively short service life.
    coolant around the spindle and bearings on a belt drive spindle is *mostly* about thermal stability. the fluid keeps the spindle within a few degrees, and you get more accurate parts. you also get less chance of the bearings binding up - which can happen if the nose gets very hot.
    I would say for your first spindle, disregard any cooling
  3. #43
    Jun 2007
    3891
    For the bearings, use grease. Oiler systems are out of the scope of what you need. These days the only machines using oil mists are large spindles running very fast (40krpm HSK50 for example). The bearings you buy will actually tell you what to use for a given preload and rpm. If you are using cheap bearings, none of this will even matter.
    I was at CMTS today and saw a number of rather nice spindles.
    you should look at:
    Meyrat
    NSK America
    Jianken
    Microlab
    Andersen
    HSD
    Those guys all make small spindles, some with motors, some belt, some direct, ranging from hundreds to tens of thousands of dollars. Microlab basically makes exactly what you are trying to do, for about a grand. Study how they have laid them out, power, bearing size, rpm limits.
  4. #44
    Mar 2014
    1131
    I've been busy with other things but managed to make some small progress on the spindle too.
    I'm still going with the belt drive design but thinking about the direct drive idea.
    When I connect the spindle with a coupling to the motor on the top then how the air cylinder works? How to design it?
  5. #45
    Jun 2007
    3891
    Quote Originally Posted by Azalin View Post
    Direct drive cant use an air cylinder generally. not impossible, but its not space efficient.
    Most will be hydraulic, some mechanical.
    you put a cross pin through the side of the spindle to actuate the drawbar, and then press that with a hollow hydraulic cylinder in the housing, or a mechanical lever..
  6. #46
    Aug 2016
    15
    What are the dimensions (and angle) for the iso20 holder I'm also trying to make one.
  7. #47
    Jun 2007
    3891
    Quote Originally Posted by vandalo05 View Post
    look up shaublin iso 20
    they have a drawing that shows the tool holder and the taper (and their gripper).
    You can buy iso20 er holders for $10. so, hard to justify making your own, unless you need something special
  8. #48
    Mar 2014
    1131
    Angle is same in all iso type holders. I don't remember right now the exact value.
    Sent from my MI 5s Plus using Tapatalk
  9. #49
    Aug 2016
    15
    7/24
    or
    8 deg 17'50"
    its like 8.2972°
    or another ?
  10. #50
    Mar 2014
    1131
    Let me check.
  11. #51
    Aug 2016
    15
    Let me check.
    Thanks bro, it will be very helpful, since the vendors are crazy they ask for $ 1000 or $ 2000 and obviously I can not pay that if I am going to start this CNC as a hobby
Page 3 of 3 123
  1. ISO20 or ISO30 Headstock For Taig
    By superchargerjim in forum Taig Mills / Lathes
    Last Post: 01-03-2019, 09:12 PM
  2. iso20 vs TTS
    By spacehitchhiker42 in forum Benchtop Machines
    Last Post: 08-25-2018, 05:27 AM
  3. ISO20 ATC spindle for Mills and Routers
    By dwalsh62 in forum News Announcements
    Last Post: 02-13-2014, 01:38 PM
  4. ISO20, ISO30, HSK 50 HSK 63????
    By 15mgtar in forum CNC Tooling
    Last Post: 08-21-2010, 02:25 PM
  5. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
