585,981 active members*
4,478 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > WIXHC MK6-V Motion card on Mach3 Enable output
    Feb 2016
    50
    I have upgraded my breakout board with a USB MK6-V motion card. I'm having an issue with the enables outputs from Mach3. My gantry mill servo drives are staying enabled. I'm using outputs 3 and 4 for enables pin set. Mach 3 has them showing they are off when estopped. But the terminals stay on. I have checked the pinout 2 and 3 for the outputs on the card. When I hit my estop or click the reset"estop" on Mach3 screen they are staying on. Before the sway they would turn off. Then when cleared from Mach3 screen would enable. I tested the pinout as an output conf. and can turn the terminals on and off just fine. But set as an enable in output setting with the pinout 2 and 3 they just stay on? I would like the drives to be disabled when I hit the estop or as usually click the on screen reset "estop". Maybe the motion card doesn't work with MACH3 enable conf.? Can I set something to use a normal output setting to use as an enable when estopped?
    ThX
    Feb 2016
    50
    Re: WIXHC MK6-V Motion card on Mach3 Enable output
    The enable settings in Mach3 output conf. does not turn off the card output when the estop is pushed. Can a macro or brain be writen to make a mach3 "output" come on/off with the estop or mach3 screen estop?
    So the Mach3 screen would be turning on/off output #3 with estop. Rather than the enable #1. I have the pinout # set right I can manually turn them on/off when set as output #x.
    Most likely an issue with the plugin. Most if not all Chinese Mach3 controllers have some features that don't work properly.
    Feb 2016
    50
    OK. I figured how to fix my issue. I made a macro. M202 Activatesignal(OUTPUT3). Then went to General Config. to initialzation string added m202 and clicked ALL RESETS. Now Output #3 comes on/off on Mach3 and terminal. I tried all the same for ENABLE but didn't work. But that is fine I can use the labeled Outputs for each of my enables needed. Anyone could probably do this for anything on a output they would want to come on for when an estop isn't set. Enable just doesn't work for me with this card.
  1. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  2. Mach3 motion card
    By Roctech-Kevin in forum Roctech CNC Routers
    Last Post: 01-30-2015, 07:52 AM
  3. Mach3 Usb Motion Control Card
    By liron in forum Mach Software (ArtSoft software)
    Last Post: 07-29-2014, 10:40 AM
