585,670 active members*
4,147 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to make a thin copper plate COMPLETELY flat/level?
Results 1 to 6 of 6
    Jul 2012
    89
    Hi All,
    I am having a bit of a challenge that I hope one of you here may be able to help with - I'd appreciate your assistance
    As it is I need to make a copper plate with a thickness of 1.5 mm COMPLETELY flat/level, i.e that the difference in thickness across the copper plate (~100mm x 100mm size) is no more than 1/100mm. Additionally, the copper plate is to be entirely level/flat - again differences of no more than 1/100mm from one end to the other. BTW although I'm aiming at 1/100 mm precision I'd actually prefer if it can be done even better ...
    I've tried milling a 2mm copper plate on my CNC (which does ~5/1000 mm in an area of this size) down to 1.5 mm - fastening it with double adhesive tape and some "steering bolts" to prevent it from moving on the tape - but the copper "curves" or bends ever so slightly so that it is no longer flat.
    I am now considering other solutions like e.g. a vacuum board but I reckon that even if the copper plate may be kept entirely flat during the milling process then the internal tensions inside the copper plate will make it go back to a non-level/flat condition as soon as the vacuum hold-down is released.
    I am also considering sanding the copper plate with different grit size sand papers and a light weight so as to not bend the copper plate during the sanding process.
    However, I was thinking that maybe one of you have already had a similar challenge - and might know how this is best done ... if this is so I'd appreciate your feedback.
    Cheers & thanks for any inputs here
    Jesper
    Jul 2012
    89
    Re: How to make a thin copper plate COMPLETELY flat/level?
    Hmmm ... might this be a challenge ... ? Still hope some of you have experience with this
    Jesper
    15362
    Quote Originally Posted by evalon View Post
    Jesper
    Anything like this would be lapped, which can be done on a lapping machine or by hand
    Mactec54
    Jul 2012
    89
    Hi mactec54,
    Thanks a lot for your feedback! As it is it has made me check out some options this morning and it seems to be the best solution for my purposes. One question, though: In this video - approximately 1 minute into the video, but it also shows on the video picture here - there's a "conditioning ring" which has a plastic like substance at the bottom of the ring.
    https://www.youtube.com/watch?v=l2_xOLs5P0A&t=67s
    I suppose this is a "wear & tear" layer so that the metal part higher up is not worn in the lapping process ... (right?) . Anyway, my question is if you may know which plastic this may be (teflon?) - or maybe have a suggestion for a more suitable material?
    Cheers & thanks,
    Jesper
    15362
    Hi mactec54,
    Cheers & thanks,
    Jesper
    The material would be something like Delrin it is just acting as a retainer, the steel part on top is just adding weight to it, so yes the plastic wears away over time and would be replaced, it all must be floating and not retained in any way
    Mactec54
    Jul 2012
    89
    Thanks again mactec54 ...
    ... I sort of guessed this while looking at the video. Actually, quite fascinating that a relatively simple setup like this can produce such a result ...
    Cheers,
    Jesper
  1. Replies: 15
    Last Post: 05-30-2021, 07:02 AM
  2. Completely New - Flat Pack Furniture
    By Smityp116 in forum WoodWorking Topics
    Last Post: 02-28-2020, 12:05 AM
  3. keeping thin wood flat.
    By Alangdance in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-07-2018, 01:22 PM
  4. Suggestions for making blanking die and punch for thin copper sheet
    By JetForMe in forum Diemaking / Diecutting
    Last Post: 07-06-2016, 02:16 AM
  5. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 06:48 AM
