584,829 active members*
5,088 visitors online*
IndustryArena Forum > CAM Software > Alphacam > ARD convert to DXF
Results 1 to 5 of 5
    Jul 2019
    ARD convert to DXF
    Hi folks,
    We are working on furniture productin and generally Autocad and DXF files does work for our basic CNC works. But one of design needed to be work with Alphacam. DXF drawings import to Alphacam and reshaped for CNC router machine wth small changes. Problem is, I need to use the same shape for laser cutting routers for metal sheets in another company. Metal laser cutting company says that "ARD can not use, the file must be DXF format".Because of they are usig different post processor i their laser cutting machines.
    I can not draw once again because correct shape in ARD format. I need to convert ARD file to DXF file....
    do you know any way to convert ARd to DXF?
    May 2011
    108
    Re: ARD convert to DXF
    Hi, You just have to choose "Export Cad" - here You can have DXF / Iges export (and more depending on the job/file)
    Mar 2020
    Quote Originally Posted by camnerd View Post
    I have a file in ard format. Is there anyone to convert it to dxf format for me?
    Mar 2020
    if you can, you can convert it in me
    Jun 2018
    Quote Originally Posted by Enesfaruk1 View Post
    Alphacam programinin kendi içerisinde baslangiç menüsü altinda bu seçenek var zaten
