585,781 active members*
3,842 visitors online*
    Jul 2019
    Need mach3 scripting and editor/debugger help
    I need help to determine why a 3 or 4 line macro, in mach3 (final version) , won't run without compile or syntax errors. Single code snippets run fine! (GetVar, SetVar, Code"xxx")
    But as soon as I embed a snippet in a simple " If-Then-End If" construct, I get a compile error at the time of the macro execution.
    Example M888: Runs without errors: reads/writes #Vars in G code program verified with "Operator/Var monitor"
    SetVar(100, GetVar(101)+3) M99
    Example M888: Faults on runtime execution, issues "Compile error"
    If GetVar(103) > GetVar(104) Then
    End If
    M99
    Running the debugger produces a compile and syntax error but no reference to the offending line or instruction.
    Another oddity:
    Works: SetVar(100, GetVar(101)+3) M99
    Faults: SetVar(100, GetVar(101)+3)
    M99
    Can't figure out why moving M99 would make a difference
    Re: Need mach3 scripting and editor/debugger help
    M99 should not work at all.
    It should be:
    Code"M99"
    And I doubt that it would work on the same line as SetVAR.
    Also, I'd try
    somenumber = Getvar(101) +3
    SetVar(100, somenumber)
    Jul 2019
    Thanks for the help. Moving M99 into the o100 area of the g code program , after the macro call, removed the compile errors and I was able to use the if- then statement. The debugger offered no help in isolating the problem.Using the m99 on the same line as the setvar didn't work(return me to the subroutine call line, but it didn't generate a compile error either which led me down the wrong path for a while. Hey, it's all good.
  1. Debugger detected in loader
    By Jarnodal in forum HURCO
    Last Post: 02-02-2015, 08:47 AM
  2. does the X3 post debugger actually work?
    By foxsquirrel in forum Mastercam
    Last Post: 06-15-2010, 08:46 AM
  3. couldn't activate the debugger
    By Bala in forum Post Processors for MC
    Last Post: 04-05-2010, 12:09 AM
  4. Post Debugger
    By littlebrewman in forum Mastercam
    Last Post: 02-24-2010, 03:33 AM
  5. Using VB as a G-Code debugger / editor
    By BonusODJ in forum Visual Basic
    Last Post: 12-22-2008, 08:49 AM
