585,962 active members*
3,906 visitors online*
Thread: Lathe Setup?
    Jul 2019
    Lathe Setup?
    I see alot of people with their lathe tool holder set at about 45deg to the work is there a reason for this or is it just preference?
    Re: Lathe Setup?
    We put ours at 30 deg. because we find that it to be out of the way for most turning applications and also is ready for doing a 60 deg standard thread when we need it, and not having to bother with adjusting our quick change tool post.
    Multi-Tasking Machining - Customer savings, and shorter lead times!
    www.northernmachininginc.com
