Hi all, i was watching this animation of a planetary gearbox, and this doubt appeared, Hope, you can answer.
What is the Cross roller bearing for in this type of transmission? It is shown in the minute 1:03
I mean, why not to use a copling sitem directly to the system? After all, in the output of the transmission is where you can find the wished torque right? Wich then is passed to the cross roller bearing, but why? why not use it directly as i said?
As you can see, i'm digging into mechanical transmissions.
Thanks for aswering!.
https://youtu.be/sO1FhoUPjiE.
