585,760 active members*
3,844 visitors online*
Results 1 to 10 of 10
    Aug 2017
    34
    Question Digitizing in Mach 4?
    I've just finished a new CNC router (CNCRP Benchtop Pro 2436) and I've yet to install the control software.
    I'm using the Ethernet Smoothstepper for machine control and I'd like to use Mach 4 but digitizing is a large part of my intended work flow, using a touch probe and the bed-of-nails method of point cloud generation.
    I can't seem to find any information on if Mach 4 includes a digitizing wizard or if there is a plugin available for it. Can someone confirm that this is possible with Mach 4 or one of its plugins and possibly point me in the right direction?
    I can use Mach3 if I have to but I'd really rather utilize the newer and fully-supported software if possible.
    Thanks!
    Aug 2005
    205
    Re: Digitizing in Mach 4?
    I'm completely new to Mach 4, so the term "point of nails" point cloud is foreign to me (I commonly work with point clouds in Rhino and know a bit about that). Please explain.
    Aug 2017
    34
    That was a typo actually. :/ Should have said "bed of nails".
    Aug 2017
    34
    I withdraw the question. I've decided to go with UCCNC instead.
    Sep 2005
    1740
    Yes I would like to do the same with Mach4. Purchased the probe and it works great on Mach3, maker of the probe has no plans to do a Mach4 version of his software. I feel I got ripped off.
    Sep 2017
    39
    Which probe did you purchase? I'm looking to purchase one that works with Mach 3, I use Mach 3 did not upgrade to Mach 4 as there is no support for my wireless pendant even though I'm using the UCCNC controller the UC300ETH. Also the same reason not to use UCCNC software due to lack of wireless pendant and Modbus VFD control. Mach 3 has been great for me so far.
    Jun 2015
    943
    Quote Originally Posted by Formantjim View Post
    Your statements are all false.
    UCCNC supports the HB04 wireless pendant as well as the UCR201 wireless pendant: CNCdrive - motion controls
    UCCNC has modbus plugin which support all flavors of the modbus protocol and there is VFD modbus plugin also.
    Sep 2005
    1740
    Mach3/4 is the most widely used CNC control system in the world. I do not recall the brand of the probe I used but its Mach4 that does not support the digitizing which worked fine in M3. The software was a bonus. However you can have both 3 and 4 on your computer at the same time… and just use Mach3 for the digitizing and nothing else. Mach4 works great and lots of support.
    BTW his wireless pendant may not be supported in UCCNC.
    Jun 2015
    943
    Quote Originally Posted by wmgeorge View Post
    Yes and mach3/4 is the least reliable also.
    May 2005
    1662
    Is this discussion about recording z heights over a series of x-y coordinates ? There must be a dozen or more software solutions available for something that simple.
    I just use a home-made probe and a g-code file with some variables to end up with a text file. I have no way to test that in Mach# but suspect the same is possible. G-code Ripper works if a GUI is preferred and probably most 'autolevel' type programs do the same.
    Re: Mach# being the most common cnc control, the folks at FANUC may argue. Then again maybe I underestimate the size of the hobby market.
    (just kidding, I understand hobby control was implied)
    Anyone who says "It only goes together one way" has no imagination.
  1. Help needed with Mach 3 and Art Fenerty Digitizing Wizard
    By Evolution VIII in forum Digitizing and Laser Digitizing
    Last Post: 09-17-2010, 11:27 AM
  2. using Mach software for digitizing?
    By Rich05 in forum Mach Wizards, Macros, & Addons
    Last Post: 08-04-2009, 02:17 AM
  3. using a CNC / Mach software for digitizing? other ideas?
    By Rich05 in forum Digitizing and Laser Digitizing
    Last Post: 01-14-2009, 05:12 PM
  4. mach 2, xylotex and homemade digitizing probe
    By gun_mike in forum Benchtop Machines
    Last Post: 03-17-2008, 02:50 AM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
