585,974 active members*
4,368 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Turret Issue after Battery Dead Al-62 SKT21 LMS built 2010
Results 1 to 8 of 8
    Jul 2011
    Unhappy Turret Issue after Battery Dead Al-62 SKT21 LMS built 2010
    Hi Folks,
    I've tried the usual reset protocols after the Battery is replaced.
    Done the Keeper Relay #5.0 to 1 and all.
    I've done the routine a dozen times pressing even a few times with the three button holding portions.
    It will set all the PMC values that I've seen to Tool 1 and looks to be all set.
    Even done power off and back on to see if there was a need for it.
    Here's where it goes wonky!
    If I don't move the turret to a new position and attempt to set tool 1 using the "Qsetter" it will open the table to tool 1.
    If I rotate the turret to position 2 (or anywhere else) it sends the table to Tool 16 and no matter where the turret is it opens the table to tool 16 forever after.
    If I try to program the turret move in MDI or Prog Mode, the turret indexes and clamps but never moves to the next line.
    I did check the switches to be sure the clamp and unclamp switches swap 0's and 1's during a manual move. It is clamping! but the line never finishes...never!
    I have been at this too long to get this far and not succeed... but folks this one is weird.
    I have even taken the new battery out and brought up the original alarm...hoping to start from scratch and no different result.
    This is only a 12 tool position turret!
    Apr 2009
    1262
    Re: Turret Issue after Battery Dead Al-62 SKT21 LMS built 2010
    Has anyone accidentally changed the data bit table? It’s possible to change number of tools using D9 bit 0 and1. Other than that has anyone activated 1/2 station indexing?
    I’d try watching feedback from encoder as well to make sure that it’s not glitching. It may be that rather than battery causing the error.
    Experience is what you get just after you needed it.
    Jul 2011
    We haven't messed with the D9 and not sure how to access. Not using half station either...
    Encoder counts 3000 each interchange manually with a margin of 1 or 2 pulses. I thought I saw it rotate one time and leave the value the same....but never saw that again and it was an even 3000 pulses/ count the next switch...I could watch for inconsistency but wouldn't it be more obvious. not an entire change with no pulses...like a missed stop or a half swap?
    HN
    Apr 2009
    1262
    A few questions:
    Does the turret lock down properly on each station?
    Does the encoder number increase by 30 degrees on every index?
    If you are getting clamp/unclamp signals does FIN signal go out or remain ON?
    I would suggest looking in the ladder to see if anything else is triggering the station count improperly.
    Best regards,
    Jul 2011
    So found a post from different model and SKT.
    Solved by changing this PMM parameter.
    Find PMM parameters (not so easy), change PMM parameter 11.0 to 1 (it should be 10000001) Hit mode select, spindle stop and feed hold
    all this after re-applying the Battery procedure.
    Digging into the why yet... ANYONE KNOW WHAT THIS PARAMETER IS?
    From the other forum...in quotes.
    "1. Set keep relay 5.0 back to 0
    2. Find PMM parameters (not so easy), change PMM parameter 11.0 to 1 (it should be 10000001)
    3. Hit mode select, spindle stop and feed hold
    4. Set keep relay 5.0 to 1
    5. Shut down machine
    6. Power up.
    7. Home machine again
    8. Hit mode select, spindle stop and feed hold again
    9. Power off again
    10. Start again and home.
    11. Just to be safe, hit mode select, spindle stop and feed hold again "
    Apr 2009
    1262
    Here's what I have on your turret. A turret recovery procedure and a Data Bit table like I mentioned before and was asking if it had ben changed.
    11.0 is mentioned, but see reference table, it looks like 11.0 is M vs non-M turret.
    Apr 2022
    5
    Does anyone have a sequence for finding the PMM parameters page in a Fanuc Oi-TC controller for a SKT 21-LMS lathe?
    Nov 2013
    17
    Should be: system -> PMM (power mate mng) -> Parameter
  1. TL1 dead battery
    By CMI10 in forum Haas Lathes
    Last Post: 10-05-2016, 04:49 PM
  2. Kia SKT21 turret drive
    By B Godard in forum Hyundai Kia
    Last Post: 09-18-2013, 05:30 PM
  3. Mazak M5 DEAD BATTERY -DEAD CONTROL
    By tired_iron57 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2012, 07:35 PM
  4. EZ-Trak DX with a dead battery!
    By Retired Guy in forum Bridgeport / Hardinge Mills
    Last Post: 08-10-2009, 02:03 AM
  5. CPU dead battery
    By LT1TRUCK in forum Computers / Desktops / Networking
    Last Post: 09-10-2007, 12:47 PM
