586,024 active members*
3,679 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > FAGOR 8037 - How do you set the Soft-Limit on "Y" Axis.
    Question FAGOR 8037 - How do you set the Soft-Limit on "Y" Axis.
    Howdy,
    I'm trying to set the soft-limit on the "Y" axis to prevent accidentally cutting into the spoil board.
    Any help is appreciated, Thank you
    Dec 2010
    Re: FAGOR 8037 - How do you set the Soft-Limit on "Y" Axis.
    Hi ,
    To Set The Y axis Soft-limit , you need to access Axis Parameter from the CNC and goto Y axis and replace the parameter for the same . You can refer the manuals which can be download from //FAGORAUTOMATIOn// website
    Please excuse my grammar & typos
    Avinash .
    For in-depth support feel to contact .
    Thank you, I will try today see if it works.
  1. Replies: 4
    Last Post: 05-17-2015, 04:14 AM
  2. Location of "x" axis overtravel limit switch on Arrow 500
    By Joe Miranda in forum Cincinnati CNC
    Last Post: 04-20-2015, 03:56 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. V2XT Y Axis Crash triggers "Limit Overload" message, need help
    By Jim Bass in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2013, 04:31 PM
  5. "Test this axis/Run", and a limit switch
    By greybeard in forum LinuxCNC (formerly EMC2)
    Last Post: 01-31-2010, 12:08 PM
