585,568 active members*
3,366 visitors online*
Results 1 to 6 of 6
    Dec 2005
    210
    Fixture for holding 31/32 Round Part
    I am looking for a vise or hold down solution for holding a peice of 31/32 round plastic peice vertically. But it cant be tall. Id like it to be under 1.5" max height. a vise with thick alum jaws would work. I would machine them to fit around the plastic.
    Any suggestions please let me know.
    Mar 2004
    1542
    This is a pretty standard procedure called vice soft jaws.
    Take the standard jaws out of your mill vice and replace them with AL or soft steel jaws. You can just make your own.
    Tighten the vice up with a couple thickness of paper between the jaws. Bore your 31/32 hole right in the soft jaws. Remove paper and clamp in your part.
    Karl
    Karl
    Dec 2005
    210
    All the vises I am finding are to tall. I dont have much Z axis so I need a vise that is under 1.5" max height off my table.
    Jul 2005
    12177
    Quote Originally Posted by Smackre View Post
    .. hold down solution for holding a peice of 31/32 round plastic peice vertically. But it cant be tall. Id like it to be under 1.5" max height....
    Fasten a block of 1-1/2" aluminum to the table. Bore a hole for the size of the plastic. Cut a slit into the hole. Drill and tap for a bolt to close the slit and then you have a split clamp that will hold your part vertically.
    Dec 2005
    210
    Thats a good idea Goef. And inexpensive to.
    Jul 2005
    12177
    A minute after posting I thought about doing it with two pieces. Makes it easier to separate the halves of the clamping hole.
  1. Locating Fixture
    By 123sxu in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-04-2009, 04:18 PM
  2. RFQ- small little round part needed
    By fastolds in forum Employment Opportunity
    Last Post: 12-07-2005, 02:04 PM
  3. Machining strategy - how would you fixture and machine this part?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 11-28-2005, 08:36 AM
  4. Self centering fixture
    By Hack in forum Mechanical Calculations/Engineering Design
    Last Post: 07-13-2005, 05:09 AM
  5. material for fixture
    By MBG in forum MetalWork Discussion
    Last Post: 03-12-2005, 08:37 PM
