585,917 active members*
3,364 visitors online*
    Feb 2011
    24
    Exclamation Taper b cutting problems! HELP!
    Hello everyone,
    I own a JS Robostar WA50 WEDM. I have problems with the taper b cutting. The thing is, the first time I made a G code with Mastercam Wire, the cut part turned out great (the one without the radius on the pictures), but something happened afterwards and I cant figure out what! The parts that come out of the machine generate bad dimensions and I get a radius on almost all straight lines (the one with the radius on the pictures). CAN SOMEONE HELP ME PLEASE, I'm having a hard time with this problem for a long time now, and I need to get back to work. Thank you!Attachment 424156Attachment 424158
    Jan 2020
    4
    please tell me the dimension you entered and the dimension which out
  1. Cutting taper on TL-1
    By AJ961 in forum Haas Lathes
    Last Post: 08-28-2014, 12:15 AM
  2. Mastercam 3D Taper Problems
    By Todd Hamlin in forum Mastercam
    Last Post: 11-11-2012, 08:31 PM
  3. Lathe cutting a taper
    By eartaker in forum Mini Lathe
    Last Post: 01-24-2011, 07:45 AM
  4. taper thread cutting
    By cncmc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-05-2008, 10:59 AM
  5. Haas VF8-50 Taper Tool Release Problems
    By SheldonB in forum Uncategorised MetalWorking Machines
    Last Post: 05-10-2007, 06:03 PM
