Hi Peter.
Slowly getting there. There was an issue with the machining of one of the pulleys I bought so that had to do a round trip back to the supplier, then one of my servo drives packed up (doing a round trip back to the US).
I have now sourced the servo motor size I wanted, and I'm using a 50:1 worm gearbox with huge amounts of backlash (so 50:1 from the motor, and 3:1 from the gearbox to the 4th axis spindle = 150:1 total). Having tried a few "air cuts" there's a lot of "slapping" due to the gearbox backlash, and that seems to be upsetting the servo drive. However, torque under load seems pretty good.
I have a used 100:1 harmonic drive on the way, which (unless trash) should get rid of the backlash issue, and I'll make another judgement regarding the servo drive then.
I'm using a 60mm idler on the outside of the belt to get more tooth engagement on the small pulley, and with moderate belt tension it all seems pretty good. The current shonky prototype looks like this (but it will get better!):
Attachment 428278
