585,974 active members*
4,338 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Alternative sources for Stepper Driver signals.
    Jul 2010
    22
    I have, among others, just bought a cheap Chinese router/laser engraver controlled by grbl on an Arduino board. I am in the process of increasing the 320 x 160mm table size mechanically and using TB6600 Driver modules on larger stepper motors to provide the necessary extra power.
    I also have a 4 Axis, stand alone controller. (TOPCNC TC55H)
    Is it feasible to build a circuit that will allow me to switch the stepper control signals between the grbl based Arduino and the stand alone controller so I have the choice of machine control? Both the Arduino board and the controller use a 24V power supply.
    Also, slightly off topic, does anyone have a source for operating instructions for the TOPCNC TC55H Contoller? I have searched both google and Youtube trying to find a tutorial.
    May 2015
    1422
    Re: Alternative sources for Stepper Driver signals.
    Sure you could do it electronically. Use a FET as a switch to block each controller output from pulling the appropriate driver line low. Yeah, that's a lot of FETs. There may be a chip which gangs them up too. If you HAVE to. Alternatively, that kind of interchangeability can be done easily by ganging the driver inputs into a connector and having a mating connector for each controller, just plug in the one you want.
  1. How do alternative energy sources work?
    By taichinhhanaHN in forum Environmental / Alternate Energy
    Last Post: 09-12-2021, 12:56 PM
  2. Newlydraw Alternative Driver?
    By firejoe911 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2011, 10:56 PM
  3. Stepper Motor signals
    By cuecaps in forum CNC Machine Related Electronics
    Last Post: 07-12-2009, 05:54 PM
  4. Alternative energy sources.
    By bluechip69 in forum Environmental / Alternate Energy
    Last Post: 03-07-2009, 02:18 AM
  5. Grizzly out of stock of X3s -- any alternative sources?
    By kdoerksen in forum Benchtop Machines
    Last Post: 12-30-2006, 12:12 AM
