585,987 active members*
4,623 visitors online*
    Oct 2005
    1145
    Create NEW gcode file in PathPilot
    HOW do you create a new Gcode file in PathPilot ? I do not see a way to do this.
    (;-) TP
    Jul 2017
    70
    Re: Create NEW gcode file in PathPilot
    Use the Conversational tab. Or if you have any existing file, go to the File tab, select it, select Copy, then Paste, rename the copy to whatever makes sense to you, then select it and click Edit. Gedit should popup and you can select all (ctrl-a) and type delete to start fresh.
    Or just copy over a blank template .nc file to your machine and leave that around as the common file to copy/paste from.
    Oct 2005
    1145
    WOW talk about a big step backwards. The EditGcode button should open a new file in the editor IF a file is not selected.
    So what you are saying is there is NO way to directely create a new Gcode file from inside of PathPilot ??
    Interesting , (;-) TP
    Jul 2017
    70
    You can also just select any file, click Edit, and then do a File > Save As to a new name.
    Oct 2005
    1145
    For those interested in creating a NEW Gcode file from scratch.
    Press Ctrl _Alt_X
    Type in Gedit {enter}
    Write your code
    Save to Gcode Folder
    Load Gcode
    Run
    (;-) TP
  1. Replies: 3
    Last Post: 04-22-2020, 05:09 PM
  2. Linux user ? Quesiton about create gcode for PathPilot
    By BlueBird1337 in forum Tormach Personal CNC Mill
    Last Post: 09-03-2017, 12:32 PM
  3. Mach3 to PathPilot what needs to change in my post and gcode?
    By thackman in forum Tormach PathPilot™
    Last Post: 08-26-2016, 04:34 PM
  4. RFQ: Create STL file from 2D JPG
    By magda in forum RFQ (Request for Quote)
    Last Post: 01-14-2013, 07:55 PM
  5. Replies: 3
    Last Post: 12-22-2010, 07:57 AM
