585,775 active members*
4,173 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Cleaning Fanuc Power supplies, Servo amps?
    May 2007
    58
    Any suggestions?
    The shop I work at cuts cast iron, some of the tooling cuts without coolant. So, dusty. But, I was wondering, from experiance, what would be a good way to combat the dustiness? We try to keep it out of the cabinets, but that is like trying to bail out a boat with an ice dipper.
    It's not what you cut...It's what you don't cut.
    Mar 2007
    122
    You could try wrapping them in filter paper or installing a dust collector onto the machine.
    Aug 2006
    93
    hi ! i have same experience in very big factory in Tehran that they working with more than 30 CNC machine always without any coolant , and always we have problems with control , power suplly .....and after we installed on all machine proper suction blower pipe to avoide the dust free running to shop and remove all of it trough out of CNC area % 90 of random error on all machine solved ....
    ok ! thats it our experience ...try it ..
    Remove the Boards and clean it by Iso Prophyl Alcohol ( IPC ) and Dry it or clean it by PCB Cleaning Liquid, and Coat the PCB with Varnish for Insulation.
    After that you can install Dust collectors
    Dec 2005
    3319
    If you internally pressurize the cabinets, you MIGHT help prevent the ingress of dust. Here's how.
    Seal up the cabinet as well as possible. Then, find/create a source of clean, filtered air to draw from. Perhaps from another room or even via drawing air thru a set of filters. Pump the filtered air into the cabinets with a single exit where you knowingly force the air that you pumped in, out of.
    If you do a good enough job of filtering the air going in, you should be able to keep the inside of the cabinet relatively clean.
    Filters: K&N makes oil wetted special paper filters that are QUITE effective in filtering air for IC engines. Actually, once they get a bit of crud on them, they actually work BETTER at trapping/filtering out small particles.
    The ingress of fine dirt, especially in off-road racing, will KILL an IC engine in very short order - especially with microscopic dirt. The K&N stuff is one of if not the best filter mediums out there for IC engines.
    Outside of using a trick separator/filter arrangement, this is a good DIY method of providing clean filtered air to a CNC cabinet.
  1. Stepper and Servo Power Supplies
    By TSJ in forum DIY CNC Router Table Machines
    Last Post: 09-15-2006, 12:10 AM
  2. Power Supplies Again
    By tintruder in forum Servo Drives
    Last Post: 02-17-2006, 12:21 AM
  3. power supplies
    By itsme in forum Xylotex
    Last Post: 02-21-2005, 07:40 PM
  4. I need some help on Power Supplies.
    By Tasos_Eco in forum CNC Machine Related Electronics
    Last Post: 02-07-2005, 08:36 PM
  5. second power supply amps?
    By sendkeys in forum Servo Drives
    Last Post: 07-08-2004, 06:00 AM
