586,000 active members*
4,834 visitors online*
    Jun 2007
    Tool unclamp fault
    I am new to this forum, so please be patient with me...
    We have a Daewoo mill, and were cutting out a cavity in a piece of HOTROLL
    steel, made about an inch deep onan 1.5 inch deep pocket taking .0150per pass. things were going fine, and then the spindal load began to creep up. we paused the machine and fliped the inserts. when we began to cut again we received a 2015 tool unclamp fault. do any of you have any idea what we could try? we have called the service center, and they have made some suggestions but so far no soultion...
    Sep 2005
    26
    You may try a M19 to reorient the spindle.
    Apr 2003
    76
    Start with the simple things.
    Can you turn the spindle by hand?
    Is the tool in spindle with the longer dog in the correct side of tool?
    Can you take the tool out and then turn spindle on with out a tool?
    Is the clamp detect switch activated in the ladder?
    Can you clamp and unclamp the tool and see the bit change in the ladder?
    These are your start points and then come back with what you are finding.
    What type of controler on machine?
    Model of machine will help also.
    9566317
    if its not broke your not trying
  1. #9 spindle fault
    By logos in forum Fadal
    Last Post: 07-23-2020, 02:56 PM
  2. kuraki kbt-11wdx tool change fault
    By MAINTAINERS in forum Fanuc
    Last Post: 04-19-2007, 04:11 AM
  3. Spindle Tool Clamp/Unclamp Alarm
    By Q12321 in forum DNC Problems and Solutions
    Last Post: 10-10-2006, 09:24 PM
  4. inverter done after #9 fault
    Last Post: 03-22-2006, 03:53 PM
  5. Fault code
    By Rufan in forum Bridgeport / Hardinge Mills
    Last Post: 09-28-2005, 01:57 AM
