585,683 active members*
4,874 visitors online*
    Feb 2004
    427
    Sliding door tracks and rollers
    can sliding door tracks and rollers be used to build a cnc plasma table? would they be accurat enough?
    Jun 2004
    51
    I think you would have accuracy issues with what you are considering. The easy way is to use a tube and use ball bearings on the top and sides. When you make the axel for the bearings just incorperate an eccentric in it so you can adjust the bearings close to the tube ( or shaft) to take the play out
    never set a pace that you can't maintain
    Traveler
  1. Gear rollers
    By Bassbuilder in forum Mechanical Calculations/Engineering Design
    Last Post: 01-27-2005, 12:15 PM
  2. Stop Buying Expensive EDM Pinch Rollers
    By Jim Abbett in forum News Announcements
    Last Post: 09-29-2004, 09:51 PM
