585,771 active members*
4,206 visitors online*
    Jan 2017
    23
    Hurco 2416 Freezes
    Dear
    Can somebody help
    Hurco then i start about in random time enters freeze and only shut donw machine help
    here in video you can see everything that hapens.
    https://www.youtube.com/watch?v=01x7ktoAnfo&t=22s
    ATC no it is take off for repair.
    checked voltage it is fine.
    change hard disk to other (not helped same problem)
    that left to check
    Computer ram (can it be?)
    Input output modules.
    Can somebody suggest that to check and were to search
    Hurco BMC 2416
    Jun 2008
    1104
    Re: Hurco 2416 Freezes
    Check the CPU for burst capacitors.
    Remove all but 8MB of RAM. Swap around to see if the fault clears.
    Remove all I/O cards and the Canbus Controller (the keys won’t function with this removed).
    Jan 2017
    23
    Quote Originally Posted by bloke View Post
    1. RAM
    i take off all ram and add just one stick, but it not works if i add 2 then it works.
    2. On this board no capacitors.
    Now will try to connect extra monitor directly to pc
    Unconnected I/O cards and Canbus.
    Optional i buy all new relays. And add them.
    Hurco BMC 2416
    Jan 2017
    23
    Problem was wire that make shorth then we found it was ok, now just have one HDD imige copy
    Hurco BMC 2416
  1. BMC 2416 ATC arm
    By rb07565 in forum HURCO
    Last Post: 09-27-2021, 04:13 AM
  2. 98 Hurco BMC 2416 ATC
    By Z-Hat in forum HURCO
    Last Post: 03-22-2017, 09:37 PM
  3. Cnc warehouse cncwl-2416
    By bollinger660 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-02-2016, 12:14 AM
  4. Thoughts on a Sharp 2416?
    By Harbor in forum Sharp CNC
    Last Post: 01-13-2015, 04:24 AM
  5. Replies: 0
    Last Post: 08-25-2010, 02:34 AM
