585,556 active members*
3,523 visitors online*
    Nov 2017
    591
    Starting a macro with an input
    I need to have a few physical buttons out on the machine for activating some things like solenoid for collet closer. Obviously I could just put a switch directly on the solenoid power, but I need the condition of the solenoid to be known by mach3 and also be able to toggle it within gcode, so basically I need to be able to run a macro with a physical button.
    So how do I do this? Do I need to just pump the macro and have it checking the condition of the input? Or is there a more simple way that I'm not thinking of?
    Re: Starting a macro with an input
    Use the Macropump.m1s macro to monitor the inputs.
    Nov 2017
    591
    Ok, figured it might have to be macropump but wasn't sure, thanks
    There is another way to do it using an OEM trigger, but it only works with 1 button.
    So the macropump is the way to go.
  1. how to Assaign a macro to an input
    By horkunkilic in forum Mach Wizards, Macros, & Addons
    Last Post: 09-25-2013, 09:42 PM
  2. Starting small NEED INPUT
    By breathe in forum Want To Buy...Need help!
    Last Post: 07-16-2010, 05:11 AM
  3. Start macro with input button
    By geahr in forum Mach Software (ArtSoft software)
    Last Post: 09-17-2009, 03:52 PM
  4. Starting CNC need your input and more
    By kirker912 in forum Benchtop Machines
    Last Post: 08-04-2009, 05:12 AM
  5. Starting knee-mill retrofit. Your input appreciated.
    By jamma in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2007, 05:41 PM
