585,992 active members*
5,238 visitors online*
    Jan 2007
    626
    Thoughts on X Axis Design
    Hi Gents,
    Still thinking about options for a future T Slot Build.
    I know it is desirable that the linear rails on the X Axis are some distance apart to help prevent resonance.
    I was thinking about ways to brace the 2 T Slot pieces.
    First thought was to bolt a section of Aluminium across the back of both sections, but this would increase the weight signifcantly.
    Then I wondered if it would be benficial to join both sections via 3rd section of T Slot, using 90° Brackets and the like.
    Pic probably explains if better......
    Would that be useful to the design or would it just be a waste of material and money giving no benefit?
    Do you think there any better options?
    Steve
    Attachment 424460
    Re: Thoughts on X Axis Design
    If this is the gantry beam, the best choice is one single large beam.
    Jan 2007
    626
    It is the Gantry Beam.
    I didn't think a single beam would be available to purchase. The biggest I have seen is 160mm.
    Is that big enough?
    I know it depends on size of router itself and what one is cutting,etc, but it seemed a little narow.
    Depends on the size of the machine, and what you intend to do with it.
  1. Your thoughts on 1500mm X axis gantry design
    By disneytoy2 in forum Linear and Rotary Motion
    Last Post: 01-09-2019, 07:06 PM
  2. DIY hobby cnc design thoughts?
    By Keonfrey in forum DIY CNC Router Table Machines
    Last Post: 05-11-2017, 04:31 AM
  3. Thoughts on my design
    By yoshimitsuspeed in forum DIY CNC Router Table Machines
    Last Post: 11-06-2012, 09:40 PM
  4. Design thoughts for a 4x8
    By Mauser in forum DIY CNC Router Table Machines
    Last Post: 08-20-2012, 04:02 AM
  5. First thoughts for new design
    By Pairair in forum DIY CNC Router Table Machines
    Last Post: 09-10-2005, 04:19 PM
