Hello,
Im looking for old 8inch floppy drive, cause i want to backup my old okuma lb15 lathe machine, im willing that someone can help me.
Hello,
Maybe if you did a search for 8 inch floppy drive instead of 8inch you would find something.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
Not only are the 8" drives expensive now
shipping from the USA to UK more than doubles the cost
https://www.ebay.com/b/8-Floppy-Drive/169/bn_7023250506
John
Hi i get a driver. But i havent the cable gor it maybe you have it? Contact me by email [email protected]
Most likely you will have to find a ribbon cable like from here 50-Pin SCSI Drive Ribbon Cables
3M 50 pin for the drive
Mactec54
Have you considered using an emulator should.be the same connections
Isn't the emulator designed for 3,5" floppies only?
Is there one for the old 8" system?
Uli
