Hi there
In my previous post I think i couldn't explain clearly my Spindle problem,
My spindle works only after I close and open the mach3, By doing so (opening the mach3), I noticed that in "Spindle Speed" Section of the First Tab (Program RunAlt-1) As you know there is a Button by name of "Spindle CW F5" and under this buttom there are some DROs that one can Enter RPM in it The RPM Values are "at the time of opening" all Zeros. At this point If I push the "Spindle CW F5" Button and then enter some RPM values in "spindle speed" DRO , The Spindle starts Running and I can Increase or decrease its RPM speed.
But If I try to run a code like usual which is by loading a G Code program and then pushing the start Button, The axis move But My Spindle would not start, It appears that the spindle does not respond to the M3 Command of the G code, and at this point even if I push the "Spindle CW F5" Button, the Spindle would not start, also the DROs under this "Spindle CW F5" Button have some values in them from the G code that even if I try to change them they would not change. At this point I have to Close and open The Mach3 in order to start the spindle.
Any recommendations or suggestions that what is going on here?
should mention that all these happened recently, It was working Fine before.
Regards
Jhonansaro
