585,781 active members*
3,919 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > New GibbsCAM plugin for threading custom threads.
    Jun 2007
    I've been a cnc machinist since 2004 and been a user of GibbsCAM since 2005.
    I've always been fascinated by threads, and have machined all kinds of wierd styles and sizes over the years.
    I've seen solutions for machining the 'single point threading' way with plain tools in MasterCAM and EdgeCAM + RopeCAM is a standalone windows programs that does similar. But the all require you to draw or provide the thread numbers yourself.
    Well, I was tired of looking up thread data, and finding numbers to draw the thread profile, so over the last 5 years I have developed a new plugin for GibbsCAM that enables you to easily program custom or large threads in GibbsCAM.
    The plugin will use a plain lathe tool (groove insert usually) and segment the entire thread profile with several synchonized threading cuts (G32/G33)
    This way, you can easily thread a large 1 or 2 TPI thread with a simple grooving tool, instead of using a full thread form insert that usually implies the risk of shatter.
    Read more about the features here : ThreadTracer for GibbsCAM
    There is a free to use verison of the plugin, that does ACME and STUBACME threads available for download.
    The complete version will do buttress,trapezoidal, and the two standards of knuckle threads (DIN405 and DIN20400) and will be available for purchase.
    Apr 2009
    Re: New GibbsCAM plugin for threading custom threads.
    having issues with the website.... is it down or is it just me? also does this do round threads? thanks
    Jun 2007
    website should be working.....i've have moved it to a new domain, but it should redirect, try https://www.threadtracer.com/ and see if that works..
    it will do round,square,triangular....most forms are supported.
    Apr 2017
    5
    I'll throw out a testimony that this plugin is the cats meow. Really works nicely, put together very well and is easy to use! Definitely makes programming odd threads a breeze, use to take me days to program some of the odd threads we do and now can do it very quickly. Plugin will process the threading operations faster than my computer will render them in simulation.
    Well worth the asking price, and Cato is very quick to help out if you have any issues or questions on plugin.
    Brandon L.
  1. New custom Topwisdom controller corel draw plugin
    By Rolcsi111 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-04-2018, 09:03 AM
  2. PlugIn simulation machine GibbsCam
    By gigilacrem in forum GibbsCAM
    Last Post: 12-16-2017, 10:23 PM
  3. THREADING A SPINDLE FOR 1.5-8 THREADS
    By JTJT in forum Shopmaster/Shoptask
    Last Post: 08-10-2017, 04:49 PM
  4. How to make custom threads
    By pleasedontcrash in forum MetalWork Discussion
    Last Post: 01-07-2016, 06:54 PM
  5. Threading Metric Threads on Mazak T32
    By fiat4726 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-08-2010, 10:08 PM
