585,727 active members*
3,971 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Can anyone identify this switch symbol?
Results 1 to 11 of 11
    Dec 2005
    504
    Under the power buttons, just right of the clamp/unclamp switch I have a switch I cannot identify. It looks like L°. See the attached photo. I'm not sure what it does. Any ideas?
    Attachment 424598
    Dec 2013
    5717
    Re: Can anyone identify this switch symbol?
    Part catcher maybe?
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2005
    504
    Part catcher maybe?
    Good guess. No parts catcher on the lathe. I'm thinking it has something to do with the tool turret but I can't find it on the schematic. It doesn't appear to do anything obvious. Turret jog or home maybe? I may have to open the panel and see if the wires are labelled.
    Dec 2012
    395
    Hi forhire,
    What's the brand and type.
    Dec 2018
    11
    Had some machine with a switch like that, it was a phase changer/select. In your case nothing will happen, because I think your phases are already set. Is it a three phase machine?
    24220
    Quote Originally Posted by forhire View Post
    If you have a decent full schematic, the SW connections will normally have wire identifiers at the termination points.
    Al.
    Albert E.
    Dec 2005
    504
    Quote Originally Posted by cncstudies View Post
    I'd expect to hear a contactor or relay click but I don't hear anything. It is 480V three phase.
    This is a Simco Turn HL-320, Hungarian made. It's an SZIM EEN-320 fitted with the Fanuc control. The schematic I have is a rough photocopy and a bit hard to read. I'll pull the numbers tomorrow and take another look.
    I thought maybe it was to enable control of the hydraulic chuck. My M code lists says M51 & M52 control the chuck but when I enter the commands via the MDI nothing happens. I need to sort that also. Foot pedal works of course.
    Feb 2009
    6028
    I've seen that before, I think (if I remember correctly) it's a barload/barfeed on/off.
    24220
    Quote Originally Posted by underthetire View Post
    Especially when it looks as though it is next to chuck open/close!
    Al.
    Albert E.
    Dec 2005
    504
    I found it. It is the Setup Mode switch S305 (100SDN1), it is connected to X12.0 (M1 pin 10). When it's closed X12.0 is high (+24). It is on the same schematic page as the door protection circuit. The machine operates in either position, with or without the door open so I suspect it has been bypassed/defeated at some point.
    Thank you for all your help.
    Attachment 424694
    Dec 2005
    504
    I got an answer from DanobatUSA who serviced these machines. They said the "right hand corner button is for over travel bypass. If one of the slide reach the emergency stroke limit switch, press this button, turn on the drives, hold it, while move the slide in the opposite direction. released, when the slide is not on the emergency limit any more."
    It isn't part of the interlock system. Now if I ever over travel I'll know what to do.
  1. What is this symbol?
    By Cavi Mike in forum Haas Mills
    Last Post: 06-16-2017, 07:43 PM
  2. Help identify sensor switch on TL-1
    By gunsmither in forum Haas Lathes
    Last Post: 03-16-2011, 08:07 AM
  3. 0.8 um Symbol on print ?
    By RMARCH in forum MetalWork Discussion
    Last Post: 12-01-2007, 04:55 AM
  4. Key Switch symbol?
    By Al_The_Man in forum Autodesk
    Last Post: 07-12-2006, 10:07 PM
