Recently, on the forums and YouTube, I started to get materials on the construction of CNC machines from plywood. The topic intrigued me. The fact is that such a machine can be assembled by virtually anyone, if there is a project and the possibility of cutting plywood on a large CNC machine. The assembly does not require the help of expensive specialists - a lathe, a welder, a milling cutter. You don't need to have any special tools. Pretty much the minimum that is available to every master.
And since I have access to a large, good CNC machine, I decided to try to implement such a project.
First, I project a stand in SolidWorks.
The machine has not yet fully finished. A little later, I will show the continuation of the series ...
Attachment 424716
Attachment 424714
https://youtu.be/XaBFQXRELe0
