I currently use a proma myplasma for my cnc plasma table. In the process of making mounts and adapters to add a router.
If I wire the router to a separate breakout board and wire everything normal to the drivers for the router(since the myplasma is a stand alone unit and uses it's own program, and the router will use mach3).. when I use 1 or the other is it going to damage the other unit since they will be tied into the same driver?
