585,760 active members*
3,825 visitors online*
    Waterjet cutting machine and waterjet cutter EAAK
    EAAK CNC waterjet cutter application:
    The cutting materials are not limited (such as stainless steel,carbon steel,copper,brass,aluminum and other metal,glass,stone,marble,granite,foam,ceramics,pla stics,composite materials...), waterjet cutting is currently the most applicable cutting method;
    Metal cutting:
    1 Decoration of stainless steel,aluminum.iron,brass and other metal cutting process.
    2 Manufacture of machinery and equipment control cabinets such as food machinery,medical machinery,CNC machinery.
    3 The metal parts cutting such as stainlesssteel flange,semi-finished,steel construction, non-ferrous metal and so on.
    Glass cutting machine:
    1 Gas stove surfaces, range hood,disinfecting cabinet, TV, bathroom products.
    2 Construction and decoration glass,automotive glass.
    Ceramic and stone cutting:
    1 Ceramic cutting for decoration and construction.
    2 Marble mosaic,granite mosaicmstone plate cutting.
    Re: Waterjet cutting machine and waterjet cutter EAAK
    Specification of EAAK CNC water jet cutting machineas follows)
    Model EK2030
    X Y axis Working size 2000mm*3000mm
    Z working height 150mm
    Cutting Pressure 380Mpa 30kw UHP pump
    Control accuracy 0.01mm
    Cutting accuracy 0.1-0.2mm
    Repositioning Accuracy 0.05mm
    Max cutting thickness 300mm(depends on materials)
    Max. moving speed 6000mm/min
    Power supply 380V 50Hz
    Environmental temperature -10-50°C
    Max flow rate 3.7L/min
    Max oil discharge 206L/min
    Max delivery capacity of oil pump 106L/min
    Control system Ncstudio (Shanghai) software IPC controller
    CAD/CAM software AutoCAD,ArtCAM
    Drive motor Japan Yaskawa servo drive motor
    Shandong EAAK Machinery Co., Ltd
  1. Need help cutting marble marquetry design with Waterjet cutter
    By VincentDoan in forum Waterjet General Topics
    Last Post: 09-16-2015, 07:45 AM
  2. Waterjet cutting machine promotion of JETE WATERJET
    By livemott in forum News Announcements
    Last Post: 09-25-2011, 03:25 PM
  3. Replies: 3
    Last Post: 09-19-2010, 02:40 PM
  4. Replies: 0
    Last Post: 09-17-2010, 09:09 AM
  5. Replies: 0
    Last Post: 09-17-2010, 08:51 AM
